DickIllyes
Tractor was running normally mowing with bush hog when died. Believing out of gas filled up but would not start. Previous unpredictable starter engaging led to replacement of starter switch, and old switch was bad, high resistance/open when turned to start position.
Now no spark and no power at input to coil, and no apparent connection to coil input from wire connected to ignition position of starter/ignition switch. Seems impossible to trace wire in harness since it looks like all are red. Almost has to be same wire that was on old switch, and switch ohms out normally. There must be some component on that line somewhere making it open but I am stumped. Any suggestions appreciated. Harnesses buried behind lots of steel.
