IH 584 Injector Leak
DrLee
Hi All,
We are a little new to the diesel engines so I could use some
help. We have an IH 584 Diesel with a leak coming from the
injector pump. Its a drip that looks like it originates from the
gasket between the pump body and the manifold that distributes
to the injectors. It drips worst when the tractor is not running;
hardly noticeable when it is on. The pump is a bosch va4
10h1150cr 8. Can we just replace the gasket or is this a
symptom of something bigger? Where do we get gaskets? Do
we have to worry about anything else when we open the end of
the pump to replace the gasket?
Thanks for the help!
Pump should probably be completely resealed, hydraulic head has some o rings next to housing. If you like, call me after 7 PM, can explain more then, have worked on pumps since 1976. Phone 574 893 4172.
Good morning.
My IH 474 has a injection pump issue. I was working the tractor yesterday and when I went to idle down it was stuck. I figured it was the adjustments. By hand I could turn it up and down by the lever on pump and it had No affect on the idle speed. It is currently stuck about half idle. (That is good, I can still work). I took the arm of the injection pump and turned the knob and it will turn in circles and has no affect. It appears the control shaft that the arm mounts to is either broke or not connected inside. I could pull the shaft to find out. Highlighted in the photo. If I need to pull the pump and send it to you I can, Im out of Knoxville tn .
What is your advice please.
Thanks,
Jim
32412229
VA4/10h1150cR 12/10
0 460 304 202
