Good day
First off I am completely new to tractor repair with that said I have a friend with an case iH gas 666 that we've be trying to get running right so for new complete carb kit installed new plugs , wires, cap , rotor ,points, condenser , coil . Battery.
The issue .
Starts up great idles great revs up great slow as well as fast returns to idle great now all the tractor does is haying so sickle mower hay rake n Bailer so it doesn't work that hard however while using it it stumbles n pops when the tractor encounters increased drag ie, a small incline , turning a corner the tractor will act up till you throttle it down ti idle for a couple seconds then throttle back up with almost no issue
Question 1. Could this be and issue with the govner " I did notice while walking beside the tractor that the linkage rod going to the carb would "snap " rear ward and stay there till the throttle was moved to the idle position "
Question 2 where could I find adjustments or testing/diagnostic video/ procedures
Any help would be hugely appreciated
Pictures and videos are most preferred as I have a learning learning disability that makes it hard for me to read and understand
Thank you in advance
The issue .
