I primarily use this IH 706 diesel as a chore type tractor. A couple of weeks ago I noticed a lot of seemingly water vapor coming from the blow - by tube after it got warmed up. Oil lever in the engine is high. Also I loosened the radiator cap and layed it aside and it looks like I might be getting pressure there also. Can just a head gasket cause this or am I typically looking at a more serious problem like a cracked head? I did replace the head gasket 5 or 6 years ago due to a bad spot between two cylinders. Was a compression leak and not a coolant leak. Engine runs fine without a miss. It ran an grain auger a good part of the summer. Thanks.
