Hello, new tractor owner and forum member.
Not a Hydro. The guy said it got stuck in neutral while working in a hay field. It sat for one year in the field with a rain cap on the muffler. Upon inspection the radiator was dry under the cap and the engine oil fill spout was full. Water on the lower portion of the dipstick. He said that he change oil every year. Took it home and drained the oil pan. Approximately 5 gallons of coolant and the oil came out...finally. Antifreeze was sitting on top of #6 cyl. and spilled out upon removal of the spark plug and fluid on top of #2 but I'm sure if its coolant yet. My suspicion is water from the exhaust manifold exhaust pipe inlet.
It has been suggested to me to remove the head and have it checked out & machine if needed.
My questions are..., should I do this and / or should I do any more diagnosing? I considered adding new fluids and running it a bit first.
Could this be a head gasket or is it more likely to be a crack in the head or block?
I am not too much concerned about the shifter / trans yet but I'm open to suggestions and advise.
I do have a service manual on the way for this tractor.
Thanks in advance!!
Thanks in advance!!
