IH 815 and 915
I'm in the planning stage of a project and need a little info on these two models. 1: What was there rated HP? 2: Are they a true Hydro or do they go through a tranny run by a pump? 3: Value of one with a good engine, cab and running gear? Machine will be stripped down and built back up it so don't care about looks and condition of anything other than what I asked about.
TIA: Merle
(quoted from post at 02:48:30 02/25/10) I'm in the planning stage of a project and need a little info on these two models. 1: What was there rated HP? 2: Are they a true Hydro or do they go through a tranny run by a pump? 3: Value of one with a good engine, cab and running gear? Machine will be stripped down and built back up it so don't care about looks and condition of anything other than what I asked about.
TIA: Merle
engine is main value. 1500 to2500. they have 3 speed trans driven by hydro motor, supplied by pump on the engine. if you find one junked with good engine,lots of the time the hydro is weak. that will cost probably 1500 to 2000 to rebuild. not sure on hp 815 about 110, 915 probably 135
Pretty sure the low profile 915 was 150 hp with a turbocharged 414. The earlier 915 used the more expensive to repair, turbocharged 407. Both had hydraulic motors that ran thru a gear box (transmission) as did the later models and probably this arrangement is still used today. Perhaps I need to get out more, but actually I'm not aware of any combine that has direct driven motors. Never had an 815 but I thought the neighbors was also turbocharged.
