Anonymous-0
Hey guys, city boy that just got dropped on a horse and hay operation.
Have two questions for anyone kind enough to help out.
1.Dashboard warning lights: second warning light down on left side. Strange icon to me. An organge circle with adot in the middle. Is this brake linings?
2. When moving slowly, front tires turn 6 inches, lock up and skid 6 inches, turn 6 inches and repeats. Something is locking the fronts up. At higher speeds, she pushes through and turns OK.
Appreciate your opinions. New comer here. Peter
The light is a control pressure indicator for MCV valve operation. it should be on and off with the clutch pedal. (others with better experience will help this as to when it is supposed to be on and off.)
The If it has Powered front wheels there is a problem in the drive system, and it will self destruct if not repaired. (opinion)
If they are just regular fronts the bearings need to be replaced and the spindles/hubs checked for wear. The situation is very not normal.
Jim
