IH Engine ID Help
Anonymous-0
I bought a complete International power unit that came out of a Gallion wheel roller. If the hour meter is correct it only has 957 hours on it. I believe it since it is very clean and runs very smoothly. I am going to put it into a 460 with a blown engine. I know the engine will fit but I was wondering if I can determine the displacement from the engine serial number? I have not been able to find anything on the internet yet.
Thanks
On the block by the oil filter base should be a machined flat surface with numbers stamped in, should begin with a C for gas then 221/263/282/301 for cubic inch of engine, diesel would be D, then 236/282/301. Then serial number usually 5 to 6 numbers.
