Anonymous-0
there is a ih #510 3bottom plow for sale on craigslist mite buy if its a good buy for good proce are these good plows? pull easy? make nice furrow pretty sure its 16in. will b calling tomorrow to find out if for sale yet
thanks
martin..
As far as I am concerned,an IH plow is the "best of the bunch".They pull 'easy',do good work,and parts are still available(Super Chief bottoms)
Yeah, $800 is a little steep unless it's got all new iron on it... You can put $800 into it if you need to replace the moldboards.
evidently you have never plowed heavy cornstalks with a 720 ih and a 588 White in the same field in addition to more trash clearance the bottoms on a White doesn't cheat on depth like an ih does
510's did an ok job but again not much clearance, why don't you just find a 565, 508, 548 Oliver/White plow? you'd be alot happier!
i know oliver/ white make good plows grandfather had a 588gf that was 4 20"in. pulled it with a 986 and maybe 2255 oliver and had john deere trailer plows for his R and his T5 crawler so maybe wouldnt b a bad idea
You're right. I've never plowed with a 720.I have plowed lots of corn stalks with a (IH)#314 and a #642.Never been a problem.I have also plowed some some with the (HI-Clearance)140.Somewhat better,but not a whole lot.The worst plow(IMO) for 'drag' and plugging have been the John Deere #825,835 and 4200.
IH plows are about the best out there. They may pull a little harder than an Oliver or deere, but you gain when it is time to work the ground.
well i cant find the add any more so getting it is a goner .. well my #312 got ran over today by a 1805 massey boss wasn't looking ahead and climbed right over top dug hole under the tractor dove it ahead on some blocks and pulled it out ..
