bradfo
The sprocket bolts on my 1975 TD 20C will loosen up after 20 or 30 minutes of use. I tighten them with a 3/4" breaker and a 5" extention. I bought this dozzer with a broken sprocket that I replaced with a new sprocket. bolts on both sides were loose and holes were wore bad. I drilled them out to 1" and used 1" grade 12 nuts and bolts but they won"t stay tight. It looks like the track links might rub on bolt heads.
what can I do. Randy
Red Locktite. Needs heat to loosen. If the bolts rub and the tracks loosen them when rolling, you'll have to grind them so they don't rub. The only other thing to do is tack weld the nuts after you tighten them. You'd have to cut them off if you needed to change sprockets though. Dave
