IH666D Misses when Hot - Help
Anonymous-0
To KEH. You were right, it was crud in the tank. There was very little but just enough to cover the pipe leaving the tank. I started by removing the line between the primary filter and the pump, very little flow. Then I removed the line between the primary filter and the tank. Again, very little flow. We got the flashlight out and could see what looked like a small piece of crud covering the outlet tube. I got the blow gun out and blew air back through the line into the tank and the flow became normal. The tank is now cleaned out. Later this week will come the real test but this has got to be it. Thanks. Paul
