IH766 fuel pump leak
Anonymous-0
I have a IH766 that is leaking fuel around the top of the pump at the circumference below where the lines are attached. I am of average mechanical ability and am thinking there is a gasket on the top that is leaking. I want to know if anyone thinks it is something I can do to take the top off and replace the gasket or are there a lot of parts under pressure that will fly everywhere when I loosen the top cover to take it off. Thanks for any help and insight. If I have to remove the pump what are all the precautions I should take.
Are you talking about that gasket under the cap up on top with the four little 1/4" bolts?
There is nothing in there except engine oil; not any fuel pressure. Only takes about a minute to change that gasket.
Allan
Alan, I think we are talking about the same gasket. Thanks for the info. I appreciate all the help on this site.
