wmasse
Can any one tell me how to line up all the disks and spacers on the brake on the side of the axle housing and put the cover on. The parts break down on the case sight also does not show a gasket where the housing goes on will silicone work.
Put dowel pins in piston housing, Stagger plates starting with steel and ending with steel. Use gasket eliminator ZPX5150 to seal hosing. Put housing on,taking care not to let any discs or plates fall off the end of bull pinion shaft.
