IHC M GOVERNOR
if you didnt get the governer shaft key in slot on the carb correctly the tractor will go to wide open upon starting. you will have to take the carb off and check the governer shaft. i alway hook the governer up before i attach to manifold.
you can adjust the idle screw out and it will allow the tractor to idle lower. the idle screw is right where the governer attaches to the carb hope this helps .
