inching pedal spring
Anonymous-0
part no. 313796 spring -control feathering pedal return. ford 801 selectospeed. This spring controls the return of the inching pedal(like a clutch pedal)also works with the pto valve. it is part of the removable control valve of an 801 selectospeed. it sits on top of the trans just under the trans cover. a simple spring that I can't find, anyone with a bone yard piece would be appreciated . Rick
Mine let loose about three years ago so in a pinch I put a hardware store one in there. Then I picked up a heavier one after. Well the hardware store one is still in there and now I have a backup, if I can
find where I put it.
Jack
You can try the Tractorhouse.com parts search. They show your part number(s), but who knows whether they are the part(s) you are wanting.
I got the heaviest spring the hardware store had at the time and as far as tensile strength goes it"s only holding the pedal up. I will change mine when it goes but I don"t really want to remove the cover unless I have to.
The fact that it"s been in there for three years with a lot of use speaks for how little the wear is on them.
Jack
