New guy.
Bought a property with a 1990 2WD 6610 Cab Tractor that has not run in 5-10 years. The best I am told is that it is good but it needs a radiator and that the AC was cold. A quick look and I can tell the oil has been changed and the main coolant radiator is dry. There is a radiator that may not be OEM in front of the main radiator which seems to be an oil cooler and the AC Evaporator. It seems to be floating (not mounted correctly). I see no grill but it may appear.
It will make me sick seeing it non functional every day but I will be in no rush so this will be a longer project.
I guess I start by seeing what radiator leaks I have and then cleaning the fuel system. If it were a cabless tractor there would only be a main coolant radiator with an integrated oil cooler...I think.
How big a headache will the AC be? What freon?
Anyone want to point me in a direction? Give me some advice.
