injection pump
John - OH
Will an injector pump from a wd9 work on a SMD? I tried to look on Case IH web site to see if they were the same part number but for some reason I can"t find a listing for a wd9. I have chance to buy one reasonable and thought if it would work, it may be worth having a spare. If nothing else some spare parts? Thanks in advance. John
They are not the same part number. You are talking a 6 series engine in the Super MD and a 9 Series in the 4 wheeler. Almost 80 cubic inches difference. I used to have a couple of IH books that had that calibration data. You need to find an old parts book that list the break down for the 2 pumps and see if the barrel & plungers are the same size.
They will work and interchange between the two. But remember the "9" series pump will put out too much fuel and cause excessive smoke. I have a TD14 pump on my MD and I cannot make the smoke go away even at an idle. I believe the distributor block is the only difference but maybe someone else can back up my claims.
Brad
it will be better to fix yours,because ,the used one is probly stuck if its sit very long.(the way to stre 1 is to fill it w/trans fluid )call me w/ more info.im a pump builder and charge afraction of what most fuel shops charge.this is not a sales pitch.but some friendly help.mike 863-381-0538
