I have a 1966 MF165. The injector pump was taken off and a gasket was replaced that was allowing the fuel to mix in with oil when tractor was sitting. Now I received it back and installed it and when I go to start the tractor it wants to max the RPM's right away. It will over rev if you don't stop it.
The throttle linkage used to move a whole inch to allow for adjusting rpm's. Now it moves a mm, and the rpm's adjust drastically. I don't know what the issue is. Governor?
Thanks, Ethan
Thanks, Ethan
