Injector pump that has been sitting
Anonymous-0
Would a injector pump that had all the lines disconnected and been sitting for 15 yrs be any good ? Its off a Ford 4600 . Thanks
Probably will have metering valve and plungers stuck from old fuel. Just cleaned and resealed a CAV DPA from a Ford 2000 out of a salvage yard, looked like heavy Wesson oil inside, even governor weights were stuck in cage, but cleaned up fine and works well. Some pumps have engine run away risk, American Bosch model 100 rotory will run wild if control unit is stuck in run position and governor can't pull it off as engine speeds up. Only salvage yard pump I trust is maybe one from a known running engine.
Around here mud daubers would have filled each of those exposed holes with their mud nests.
Last summer I bought a 3 cyl diesel that was 35 years old but had never been run. Pump would bleed but I could not get fuel to the injectors.
So with the injector lines off at both ends I took a small electric fuel pump and hooked it to the injector pump inlet and filled the whole injector pump with nearly a full can of PB Blaster while I turned it over. I let it sit for a couple of days and then tried it again.
It immediately started pushing PB out of the ports so I used the electric pump to push the PB out of it with diesel, hooked the lines up, bled everything again and the engine fired right up. It ran and stunk like crap till all the PB got out of it then settled in and ran perfect.
As much as it costs to have a pump even looked at I think it was worth the effort and the waste of a can of PB trying.
The tolerances in an injection pump bores are almost zero - any accumulation of moisture and the ensuing flash rust will turn the bore into sandpaper the first time the plungers move. It might be able to be freed up and run but I would almost guarantee you that the output pressure will be well below the minimum required for popping off the injectors reliably. Or maybe not. Stranger things have happened and yours might work fine. If it does, you should immediately go buy a bunch of lottery tickets.
