Installing a sleeve in a long 445
Rickey H
Hi all, anyone got any input on this. I have ordered a manual, but I understand that the block or sleeve has to cut whats the deal on this?? need input Thanks Rickey
I may be way off base, but isn't it a Fiat based tractor? If it is you may need to cut the sleeves out with a boring bar, install the new sleeves and then finish it to the correct zise. Do they have oversize pistons for those?
I made a hydraulic puller and installer for the sleeves on a long. The new ones were rough cut and had to rebor it after you press them in. 510 pistons are .090 oversize (if I remember correctly) but I have not tried to bore a 445 out to take one.
