(quoted from post at 06:28:45 05/16/18)
This is my crude attempt to decipher the AN description
Production code: 5C11b:
Made on March 11, 1965 Day shift
Not quite. It was made on March 11 of a year ending in a 5, but the serial number C448947 is a much later serial number. Most internet sources would tell you that is a late 1974 serial number, but the internet isn't always perfect, so my guess would be that it is actually an early 1975 serial number so it was made on March 11, 1975.
I am not clear on this, but the industrial 4110 had the option for an independent pto, but was listed as available on the powershift which had 10 forward speeds and 2 reverse. Shuttle and powershift are not in my knowledge base.
The 4110 had the rear axle with the outboard dry brakes and single reduction gears like the 2000/3000 series, and so the only independent PTO available was if it had the Select-O-Speed(10 speed powershift) transmission. The only non-S-O-S tractors available with independent PTO during that time period were the ones with the rear axles that had the inboard wet brakes and double reduction gears like the standard 4000 and 5000 ag chassis models.
D1114C would be a 4110 with diesel engine, independent PTO and an 8 speed transmission, but if it's truly a 4110 with an 8 speed then it couldn't have independent PTO. Can you post a picture of the rear axle?
