kenstrac
Looking at a 574 diesel w/loader 3300 hrs +
smokes a little needs wiring ,brakes don't work parking or foot,tires 10%,2 PTO shafts over all cond.poor whats it worth
I would say stay away. We have one. Steering cuts out brakes go away a few days after you bleed them. No loader though. You have to completely split the rear end to fix the brakes. Ours smokes too. We have only had it a few years had to redo the motor a month after we got it. I think my grandpa got jipped big time. Just my opinion.
I always thought they were a very attractive tractor. One time I went and looked at a used one and was pretty disappointed with the machine. It seemed to really move out- faster then I was used to from a farm tractor. Wouldn't go into all the gears and they adjusted it several times while I was there. I can't remember what else was wrong with it but, I was no longer impressed. They are not worth near what this place wanted for one then and one in rough shape wouldn't be worth as much. Maybe $4000 if it was in excellent shape. Maybe $2000 in rougher shape. Work down from there.
We have had one for 30+ years it has been a love hate relationship it is a good nibble tractor for loader work. The hydraulics are the down fall to it.
The brakes if they need bled al the time just remove that third valve down under the battery as it is the cause for the air in the brakes issue.
Ours has always been slow for loader work on the lift. There is an external pump for the right side of the transmission that would speed up the hydraulics. The pump requires an in line filter there is a casting that bolts to the trans mission side that the pump goes to. It is a spendy setup to say the least. That little 12GPM pump just don"t cut it for loader work that is inside. If I had to give more than a $1000.00 I would walk away from it. Ours has smoked since new I always figured it was for all the idling it gets as a loader tractor scraping barnyard and close quarters work.
They wanted to give us 4000 the way it is. Yeah ours is geared way to high. Good on the road, you could skin it back (if you had enough faith in the brakes).
That series tractor likes to burn valves. If the brakes fade just put new kits in the master cylinders. They all had wiring issues to the lights.
I have a 574 and wouldn't trade it. I gave $4,700.00 for mine and it needed a valve job when I bought it. They wanted another $700 to do the valve job but I did it my self and glad I did. When I pulled the head it needed new pistons also. I put new pistons, rings rod and main bearings and had valve job and new springs installed on the vavles plus all the needed gaskets for $700.00.
I see a lot of Kubotas out there but I've been inside of them also and they are just an oversized garden tractor as far as I'm concerned.
Well, it's probably going to depend on what type of maintenance/abuse it had.
Dad bought a 574 diesel new in 1978 with a new IH mount-o-matic 2250 loader. We ran that tractor to 5800 hours and traded it off just a few years ago. It had been worked and overworked doing stuff it was too small to do. We put 2 clutches in it, and that's it. It didn't owe us much.
