Anonymous-0
why dont anyone talk about the mach index of a intake port?
OK since I cant get to many to nibble . I was looking at crank stroke affects on piston speed . piston speed on airflow velocities then the csa and intake valve size for a specific head as to what rpm the head would be considered choked . .(quoted from post at 18:36:34 01/16/11) mach speed of sound . dave jr updraft carb needs velocity don't you think?
If I was going to do advertizing to market a head it would be tested with the largest bore fixture my flow bench would support and numbers at high lift stated.(quoted from post at 11:15:21 01/17/11) Crutch I was looking at a 7 inch crank with a head of a csa a little over three inches could get into power reducing frequencies toward 2200 rpm and go subsonic at a rpm just below 3 grand.
I truely hate that. knowing the mach index can let you know what to do with intake opening and closings .The higher the value of the mach index the later the intake valve should be closed to increase and maintain volumetric efficiency.(quoted from post at 14:05:10 01/17/11) Thanks I learned something today.
Well guest crutch me and regular crutch were talking mach iindex not minimal cross section area.(quoted from post at 21:37:20 01/17/11) Here is a ballpark formula for Minimal CSA.
mcsa=rpm*S*B^2/190000
so what i get is 2200 x 7 x 4.5^2/190000=1.64
No where limited from what I can tell, except I guessed at 4.5 bore. Also the constant might need to be adjusted for VE.
http://www.v-eight.com/tech_forum/viewtopic.php?t=148(quoted from post at 06:34:30 01/18/11) Mitch, the MCSA is what sets velocity. There will always be a mcsa and at that point velocity will be the highest. Some say it should be the throat, others say futher back up the runner. In either case, at peak torque rpms, with velocity the highest, VE should be the highest. With it futher up the track, the thought seems to be port volume to feed the cyl after piston reaches bdc. Others think the velocity has to remain high until it passes the valve seat. Again, with the low port heads, who knows what you get into trying to make the fuel/air turn.
