wore out
I've got a 4430 in the shop to clean up some hydraulic and engine leaks and found the wire that grounds the SGB to the chassis burned in two.
I don't know how long ago this may have happened, there are no known electrical issues and most of the lights are working so there must be an alternate ground path.
I wonder how that could have happened without some line, linkage or wiring harness ground not having flowed current, as well and gotten damaged?
The entire area under the cab was packed full of oily debris, I can't image if the event happened in the last years with all the mess under there that a fire wouldn't have been started!
What could have caused it, connecting a jumper cable to the SGB somewhere?
Welding on the tractor or an implement with the welder ground attached to the SGB?
A lightning strike?
Or?
Ha anyone seen this?
Wire is Key #31, at the right front SGB mount.
A lightning strike?
Or?
