International 175-C (1982) Problem
Anonymous-0
We recently purchased the above loader and had to replace the turbo and repack main cylinders....tried it out and it ran great...found a leak at the belly pan...the main hose going to the torgue converter had rubbed a hole in it. We took it off and of course...several gallons of hyd. oil ran out and we caught it. Replaced the hose filled up the transmission...now it won't go into gear and the "clutch prssue" is 0....any suggestions????
I've never worked on this model, but you might try breaking the new line loose where it connects to the converter. It dosen't seam possible, but it could be air locked.
