Dave H (MI)
I don't know how many Octobers I have spent working on this tractor but I have posted about it each year if you are interested and want to look back. This is the one time of the year where I can do it and I can never seem to get it done. One year it sat because of health problems. A brief history...
I used this tractor a lot around my smallish farm. Then the rear main seal went out and it was not useable. I had just been using it and had parked it outside to find a lot of oil on the ground. So I covered the exhaust, etc and left it where it was for the winter. In the Spring I pulled it in, split it, had the seal retainer resurfaced and put it all back together with a new seal only to discover the engine was stuck and there was no getting this tractor back together. Finally ended up pulling the pan and the head and found the tractor had some water in the pan but otherwise looked fine. Soaked the cylinders and was able to get it loose. Cylinder nearest the operator had a small amount of rust so pulled that piston. Cleaned it and the cylinder wall. One ring broke in this process so I replaced the set. Put it back together and all seemed good. It turned freely when I left it last fall, so I squirted some oil in each plug hole and left it. It was not going to start and I was out of time for the year. For whatever reason I had not looked at the carb and it turned out that it was a mess, so I ordered a kit and rebuilt it over the winter. Because of my memory issues I had a carb guy look over my work and he felt it was good. That brings us to 2024.
Put the carb on the tractor in early Summer. Made sure it had fresh gas and that it was running out the drain in the carb. Hit the starter and it cranked it around a couple of times, slowed and there was a whiff of smoke, so I stopped. My sense is that the engine is stuck again but not real sure how to tell. Not understanding how this could be either with it sitting in the dry shop all winter. I am about worn down as I can get on this project. Looking for advice on what to do next? Any advice on what direction to go?
