I purchased a 684 last year and all was well until a week ago when I checked the oil and noticed it was high. I check it prior to when I use it and this was the first time I noticed it. There was a strong smell of diesel as well. From what I've found, it looks like chances are that it's from a seal in the fuel pump. I have 3 questions: 1. Is there a place to check for a leak that is easy to get to where I can use UV dye near the pump? 2. Is there a seal that goes out on these that is common that will cause this problem? 3. Would it need a professional rebuild, or is this something that can be replaced by removing the pump?
