International b275
GwLung
Can anyone tell me where I can find a new air breather hose for a diesel b275. It has the inline injector pump with a a diaphragm. I have the part number but searches haven t brought anything up. Even called Case/IH dealer and the part number didn t bring anything up. Thanks
So do you use that part number for your safe
combination as well? You sure are not sharing it. There
is also a serial number break for a change in the hose
as well. Probably does not matter if it is not going to
be available any way. The description is a bit off for
that first option so I wonder if that part number is even
right. Is it just a rubber hose elbow as shown by the
parts diagram in the link? If so I would recommend you
get chummy with your favorite auto parts store so they
will let you back to browse through the radiator hoses
they have in stock. Fairly likely you will find one you
can buy and cut the elbow off of it and be back in
business.
CNHI IH B275 online parts diagrams
(quoted from post at 23:46:09 03/02/23) So do you use that part number for your safe
business.
quote]
First of all I didn t have a the number in front of me when I posted, just seeing if anyone has ever run into this. I ve restored a B414 and was able to find most parts even if they were overseas but this search hasn t brought up even that option. Yes the part number is correct as I have a parts book. It s the number listed for a tractor with a Venturi. Part # 706 222 R1. That was going to be my next move was auto parts store. It s 1.7" diameter on the Venturi side and 2.0" on the breather side. It s about a 45 degree elbow. My apologies for not giving all the info.
Do a search with out the spaces. 706222R1 you may get lucky, I did but I cant tell you price or inventory.
Hope you did not take that too seriously. If I said the you were ..using it for you safe combination.. do you really think that was meant to be serious? I hope I do not come across as straight up grouchy. Some people who post here I believe could easily taken as ..gruff.. however they for the most part seem to know there stuff. And I was not accusing you not having the wrong number either. The CNHI part book I linked if you look at the first option for number 3 it calls it an ..electrical connection.. so that is why I said that about the incorrect part number. I do see it comes up in ..avspare .. I would be cautious about that site. Although not to long ago someone posted here about buying something through them and he reported nothing negative. I think he even claimed to have talked to one of the owners. Good luck!
