International b414
grizz665
Have a b414 with a 1501 loader I think its getting air in hydraulics two different size suction line 3/4 on left with a sleeve on it and 1 inch on right should they both be the same ?
I have a IH424 with 1501 FEL and I believe the suction side (bottom tubing with filter on the inside) is larger tubing than the pressure side (upper tubing). I'll try to confirm tonight. Maybe check the filter where it goes into the housing under the seat and check the level of the hydraulic fluid.
