International block
Adam1992
I was needing a 301 international block for a pulling tractor thought I got one but once it show up today I m not real sure it is. The serial number on the block is 306750r11? If anyone could help me out I sure would appreciate it!
306750R11 is the CASTING number, not a "serial number"" and indicates a C-301 block.
I meant casting number I m not sure what I was thinking. I got another block that was messed up boring it the casting number on it is 382097r1 and was told it was the one I needed. What would it be cause the deck heights r different between the two
Could be as simple as the counter bores needed cutting to clean up some wear on them then the sleeves shimmed to the correct height. That or different sleeves for a multitude of reasons. Not a big deal just have to check your deck height when going together.
This is a block I have that was from a 706
gas. Im not sure if it had sleeves but it
has the same parent bores as D282 and would
take the sleeves with the small flange. The
bore is 3.875. Its possible a C301 is a
parent bore version of a D282.
(quoted from post at 02:11:35 03/04/20) Could be as simple as the counter bores needed cutting to clean up some wear on them then the sleeves shimmed to the correct height. That or different sleeves for a multitude of reasons. Not a big deal just have to check your deck height when going together.
C-301 is a parent bore block. No sleeves.
Both blocks I got neither one had sleeves in it. But one measures 3.56 on the bore size and the other was 3.8125. But was told they where both 301s but I don t think that s the case
Just curious, what did you have to give for block? Got 301 here out of combine thinking about selling if I can figure price out.
I think I asked this question before but
forgot. Will a c301 block work to make d282?
I think the answer was no but not sure
again.
Ok I found out today that this is in fact not a 301 block. The casting numbers had been ground off and the new number was stamped out instead of cast in the block not sure y someone did that. Thanks for all the help and insight from everyone!
right side of block up by water pump on a flat spot will be stamped 301 gas and diesel I have two that way.A 282 sleeveless will make you a 301
