International Farmall Cub
Satohbill
Does anyone make a reliable aftermarket carburetor for my Farmall Cub. The last one i bought ran great for a while then started flooding.
Sorry I realize I am in the wrong forum
This post was edited by Satohbill on 12/21/2023 at 04:02 am.
I recently put this carb on my Farmal C. Bought it off amazon
for $34 plus tax. It works fine after I make all the
adjustments.
Dosens Carburetor Compatible with IH-Farmall Tractor A AV B BN C
Super A Super C Replace 352376R92 TSX156 TSX157 TSX319 354184R93
355485R91...
(quoted from post at 05:37:06 12/21/23) Grandpa love just answered that question on the Farmall and IHC forum. I would follow his advice.
Dave
I couldn't find Dosens carb on Amazon. Will look on Ebay.
I can't send you a link to Amazon without sending you my
personal Info.
However, go to Amazon and search for Dosens carburetor
Go down the page and they have 18 IH carbs in stock.
(quoted from post at 06:23:49 12/21/23) I can't send you a link to Amazon without sending you my
personal Info.
I found a Dosen's carb for the Super A but not for my Cub.
We have used several Kipa carbs from
Amazon. This is an IH carb clone (We seem
to buy Cubs with missing carbs)They work
perfect straight out of the box. We have
one on our cultivator cub, used it for 3
seasons, zero issues. Carb flooding can
be caused by the smallest piece of grit in
the needle. Is your sediment bowl screen
in good shape? What year is your cub? The
newer cubs used a zenith carb. I have a
couple of those, tested, and ready to
ship.
(quoted from post at 07:02:35 12/21/23) We have used several Kipa carbs from
ship.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto168912.jpg>
My cub has the squared of front. I think it is a 66 model with 12 volt generator. But recently changed to alternator. Whats the price on your Zenith carb. Can you send me pictures and prices.
Im trying to get some information on a center scraper hydraulic lever position lever for a customer of mine. its a 50 with the square front i due believe. i just put a new o-ring on the front of the position lever, but it has now gotten extreamly stiff and i feel that their is air in the system along with the rod being bent?
Start a new post. You will get over looked in an old post. ****. But a '50 cub would have the round hood, not square. Not at all sure where you put an o ring???? We have worked on 60+ cubs, can't figure out where you put that?? What rod is bent? From lever to touch control unit? Air in the system? Remove the fill plug and work the lever back and forth. Moves hard?? Spray a good penetrating oil on all the connections.
