Int'l 300 and 340 Compatibility?
Eric Powers
So here's my dilemma...I have a 1955? 300U with Davis loader and hoe. No power steering, TA likely shot. Motor runs ok, but there are clutch and/or tranny issues that will be a mystery until the tractor is split (paid $1300 for it). I also have a 1961 340U with a badly stuck basket-case motor. No TA, has power steering, solid tractor (paid $500) Plan A was to free the motor and grin like a son-of-a-gun when it ran, swapping the loader and hoe over. Plan B was to replace the 340's c-135 but I'm having trouble finding a running motor for less than the cost of a rebuild. These tractors are in two different locations now, so I can't even eyeball them for compatibility. Grasping at straws but wondering if the power steering unit from the 340 would fit on the 300? Will the front-mount hydro pump from the 300 fit on the 340? These are the things that keep me awake at night. I'm in over my head but have a good mechanic I trust. Trying to keep my costs down or I'd be making payments on something 50 years newer. A friend said sell 'em both and start over, but I am intrigued by the thought of owning a good running tractor with loader and hoe for $2500 or less, and I don't like giving up. I'd appreciate any thoughts or constructive comments.
Hummm...you talking apples and oranges here. The 340 is based on the C series tractor. It is much lighter than the 300 which was based off the H.
A few things might work, but they will take some modification. I do not know for sure if the power steering will work or not. They are covered in the same manual and the rebuild procedures are the same.
Good luck...but you have a ton of re-work in front of you.
About the only reliable way to figure all this out is to get the tractors together, so you can eyeball and measure them side by side. I have tried, with limited success, to take measurements and make drawings to compare, but there's no substitute for being able to look at both at once. Another possibility is to get parts manuals for both, to compare corresponding parts.
I have both the 300U and the 340U here. They are very different tractors, 2 different generations. The engines will not swap. The power steering does seem to be interchangable, but the hydraulics systems are different, so you may be missing critical parts.
As a loader tractor, I find the 340 to be the better, but it does have less Hp, less weight, and smaller brakes. But the front axle seems better fitted to an appropriate sized loader. We had thought the 340 would be dedicated to a backhoe, but the weight of the hoe and the digging forces seemed to be too much for the 340. So we never mounted the hoe.
Look carefully at your hoe, If the cylinder rams are rusted they will tear up their seals the first time you move the cylinders, and then the hoses can add up to be a whole bunch of $$$.
The front mount pump should fit both tractors, but you may need an adaptor to the front pulley.
Both models are good utility tractors, but neither is strong enough to do any real digging, unless you are very careful not to strain it. Just my opinion....
Paul in MN
