Inverter Thoughts
pete43011
Seems like pull start tools (chain saws, trimmers, leaf blowers, etc) are getting harder to start as I get older plus I don't need to use any of these a lot, so I'm thinking about converting my 8N to 12 volts and hanging a fair sized inverter under the metal Dearborn canopy. Then start acquiring electric powered replacements for my "hard to start" stuff.
Can't see why this won't work out pretty well and maybe be handy for some other needs I haven't thought of.
Interested in input from the forum on this notion.
Inverters are a great source for most small scale needs. Here is the problem, it is very hard to supply the amps needed to run must "big" amp draw items. A leaf blower, or a ele chain saw will draw 5-10 amps if not more. A circular saw will spike out at 15 amps until the motor reaches speed. I have used a 12 car battery at football tailgates and is worked great, we had a 24" lcd, sat rec and stereo system all hooked up......it would run about 2.5 hours before the inverter kicked out due to low voltage ( we were using about 1.2 amps - we now use a small honda gen. Not sure how much you are looking to spend, they make inverters for trucks for large amps applications but as total watts go up so does the price! Other thing is that whatever extension cord you use should be a large gauge too.
Inverter choice
Portable generator and electric tools are a great combination. Carry the generator on the 3-point carry-all.
(quoted from post at 20:56:34 11/01/09)
I will agree.
Maybe an electric start on the generator?
I'd go with a generator. Check the want ads or craigslist, you can find them resonably priced. Wait a few months after a flood or wind storm and there are lots for sale, usually at a very good price. I picked up a 6KW Honda in a divorce sale for $500. they retail for $2600
A friend had a small ac generator belted to his FarmAll A.He used it to run an electric chain saw in the woods.There are some chain saws with easy start systems now.
