I know this isn"t a proper place to ask this, but I haven"t found a more active farming group.
I"ve used this pump for 9 years, and its become increasingly difficult to get started. I"d replace packing and it would work again, but still, never as easy as it had in the past.
Its a centrifugal irrigation pump (3-phase, 5hs). It just won"t build up pressure and suck water after initially starting it. I"ve replaced the packing, cleaned the intake, checked the intake all the way up into the pumps intake.
When working correctly, I"d prime, shut off the prime valve, start the pump - the pressure jumps to 40-50#.
When its not working so well, it bounces between 5 and 15# before building up pressure. I usually have to crack the outflow valve to get the pressure to climb - before opening it up fully.
Now, I start the pump, it sits at 0# for about 30 seconds, then climbs to 3-5# and sits there until the packing gets hot and I shut it off. No water comes out around the packing.
Strange thing is, nothing really changed since I turned it off last (a week ago). It was hard to start then, but never this bad.
I replaced the parts to my hand prime pump since the rubber had an aged wore out hole in it - but this new one seem different. When I used to use the hand prime, I"d pump until water comes squirting out .. now when I pump, I feel it getting stronger as if its filling with water, then it then suddenly stops me from pumping (as if its full... maybe this is the way the backflow nipple is supposed to work?? -- its been a long time since I"ve had new prime pump components...). Some water does come out of the prime pump, but very little compared to the stream I"d get before. Which is correct?
I"m just spewing info in hopes it helps someone go, "aha! you goof, here"s what you"ve done wrong...!"... maybe??
He"p?
Thanks!
He"p?
Thanks!
