(quoted from post at 00:18:39 03/11/11) If you used a Dubuque or Mannheim to run hydraulic motors or other high flow loads. Without the optional ported filter cover return that Deere sold for such applications.
(quoted from post at 07:58:07 03/11/11) Hydraulic oil and seals should not be damaged running at temps up to 200-220F. Such temps feel too hot by "normal" hydraulic standards found on loader hydraulics.
(quoted from post at 18:26:00 03/10/11) Is a 2955 with a cab a good tractor ? What were the typical problems with them if any ?
(quoted from post at 08:57:51 03/11/11) Figuring if a 10HP hydraulic motor was running at a hydraulic system efficency of 85%.
There would be approx 1200 watts or 4100 btu/hr of heat disipated into the oil. In addition to all the other souces heating the trans-hydrualic system.
(quoted from post at 10:21:33 03/11/11) Any pump , motor and associated lines/valves will have losses.
Come to think of it I missed the pump and line losses on that 10HP motor example.
Heat dissipated into the oil would be closer to 3000 watts/10,000+ btu/hr.
(quoted from post at 19:32:39 03/11/11) if closed center is a bad system whats the best way to run a 7200 vac planter.
