That made some nice bales at the end, spent some time with a 315 baling hay in nearby fields, always thought highly of the 315.
There are some old school Ford Tractor & Equipment stickers on it, be great to see a close up of those. That is pretty cool that you have it repaired and it's making such nice bales !
Here ya go.
Baler was found in a barn near Tupelo.
Cutting, raking, baling are the fun jobs- pitching small squares , not so much!! unless you have hard working crew! Mark.
Well if doing hay is fun well you can come here and do mine LOL. Doing hay while not all that bad is not a whole lot of fun unless you think work is fun
Lookin' good! A couple of suggestions though: Be sure to keep your RPMs up. Running slow can be very hard on an older machine. Next, bolt a 3 ft. piece of 2x4 under the end of the bale chute. You want it 2 inches right of center sticking out the rear about 18 inches. You attach it with one 9/16 round headed bolt. Angle it off to the right a little and as the bales fall off the end of the chute it will make them roll to the left so that they won't be in your way next time around. You use just one bolt so that it is adjustable. If you want to get fancy they make a chute extension that tips them to the left and also makes them land on the cut edge.
Arlen, thanks again for the spring,and advice on getting it going. Very gracious of you to spend so much time on the phone with us! only drew blood in 4 places! Lol the finger between fly wheel and frame was a good one!!!
Wonder if the owner of Tupelo Ford Tractors was married to Becky Thompson. "... and they bought a store in Tupelo..."
Thank you sir, can't go wrong if it was barn kept and or under a roof. Always like to see these sticker, locally, I look for ours and did find a rest-o-ride seat with our dealership sticker on it, on CL a few years back, I bought the darned seat just for the sticker, it was on the underside so when you have the seat flipped up, you see it.
The hay in the chamber was too loose for the knotter to tie. That was why I replied on U Tube that you needed to cycle the knotter before putting hay in the chamber, so there was twine locked in the twine discs to hold the hay in place.
Loren
