I will need to go measure. No groove, no holes. I don't know what the original pin had.What are the dimensions (diameter and length) of the pin you need? Any special features like a groove for a snap ring or threaded holes? I have a pretty good stash of hardened pins.
I have a couple here I was gonna haul to scrap. Send a pic of what u need. I got so many of them jacks. At least 6.I have a 48" JACKALL JACK MARK II JC HALLMAN MANUFACTURING CO LIT KITCHEMER ONTERIO CANADA
I bought it about 1965 in Reno, Nevada
It has a broken casting that selects up or down. The casting has M 35 cast into it. Does anyone know where I can get a replacement part?
they are just roll pins , measure and go buy them.I know this discussion is WAY old. I have this Jackall Jack Mark II. One of the cross pins in the lift pin broke. I used a long roll key for a while. That broke. Any other suggestions for what to use? I have a bag that has some pins in it but I think it is labeled HI-LIFT and not Jackall. Those don't fit.
never mind its a 16 year old post.I have a couple here I was gonna haul to scrap. Send a pic of what u need. I got so many of them jacks. At least 6.
ha ha , well ya i know. till it got revived today. i guess i was replying to tiggy's post today. then went to look and saw its and old post so it gets confusing. just start a new post if looking for something.Not all of them are that old
That old you will probably have to make the part.I have a 48" JACKALL JACK MARK II JC HALLMAN MANUFACTURING CO LIT KITCHEMER ONTERIO CANADA
I took the whole jack into hardware store. Figured out that 3/16 roll pin 2" long works.they are just roll pins , measure and go buy them.
A drill bit will never work. It is brittle and will break. I have about 6 of them jacks and only have broke the pins on one jack. The important thing is to keep that mechanism well lubed. I lube mine when I need to use the jack with a spray lube. Keep them lubed and them jacks work very good , no lube and them pins get sticky.I took the whole jack into hardware store. Figured out that 3/16 roll pin 2" long works.
Drill bit might last longer if I can figure out how to make it stay in.
I learned the hard way to never ever force anything.A drill bit will never work. It is brittle and will break. I have about 6 of them jacks and only have broke the pins on one jack. The important thing is to keep that mechanism well lubed. I lube mine when I need to use the jack with a spray lube. Keep them lubed and them jacks work very good , no lube and them pins get sticky.
