JB Weld Gas Tank
WayneMo
Has anybody had success with JB Weld to patch a tiny hole in a gas tank?
I tried one and it failed in one place. It appeared the gas seeped underneath the epoxy. A good friend who is knowledgeable on epoxy's told me that it should work and that I probably did not get the surface "wet" enough from the epoxy to bond to the metal. He said that the more liquid materials bond better for this reason, as opposed to the faster drying thick materials. I wonder if the galvanized surface is a factor also.
Any epoxy experts out there?
O'Reilly's sells a sort $10 cheap made just for that and is seems to work well I know I used it on one of my trucks 6 months ago and it is still holding
use Gas Tank sealer instead of JB.buff the area with the sandpaper,get it CLEAN!,apply according to directions.It works!
FWIW
Had a 250 gallon overhead fuel tank given to me, it had pitted where the tank sat in the straps, with a couple of very small seeping leaks.
Took the tank off the frame, rolled it upside down, wire brushed it to get rid of all the rust, cleaned and degreased it, applied regular JB Weld (not the 5 minute stuff) to the whole pitted area.
Remounted the tank so the repaired area wasn't sitting in the straps.
The most gas I ever put in it is 150 gallons at a time
Been 7 or 8 years now, no problems yet....knock on wood.
Fred
don't used a wire brush, can make a spark, used a brass brush, knew a guy that bruned down his shed with a wire brush and gas.
FWIW...I used JB Weld on my F150 oil pan. It had a pinhole leak. I cleaned the area, applied a abundant amount of JB WELD and then put a small screw in the hole. That was 12 years ago and it still doesn't leak.
I also used JB Weld on my 8N engine block around the drain valve (cracks around the valve). Found the cracks AFTER I bought the tractor. Actually, first I zapped the cast iron with my MIG welder, then filled in with JB WELD. It has never given me a problem either.
Good luck!
(quoted from post at 02:33:26 03/18/10) FWIW
Fred
ame experience with twice the tank (560), twice as many years ago and it has been full many times. Worked better than I ever expected.
JB Weld is a product that comes in several different versions. I would suggest using the one that is labeled for and designed for the purpose. If it were mine I would skip the JB and use the gas tank sealer that the others have already vouched for.
I can only speak from my own experience.
Bought my main tractor 5 years ago. Gas tank was leaking. Started cleaning it up and found someone had used JB weld to seal a leak. It failed. I cleaned it up and soldered the pin holes. It's still holding.
On that same tractor the float bowl was pitted and leaking. (aluminum carb) I cleaned it up real good and used JB Weld. Let it sit for about 3 days before I put fuel in it. Worked good for about 10 days then one morning I came out and found about 2 gallons of gas on the floor of the garage. JB weld had failed. JB might work for others but I will never use it on or around gas again.
I have one still working several years after the repair. Cleaned the tank down to shiny bare metal and sprayed several times with brake cleaner. JB Weld held good and is still holding. Surface preparation is critical.
Another good product is the JB Weld water weld product. It comes in a big tootsie roll looking setup and you just cut/pinch off what you need, knead it together for a few seconds, then press in place. You can use it on wet surfaces and will still dry.
HTH,
Dan
if the tank is empty, it should work.. though you can get a putty style that is for gas tanks.
drain tank.. sand area, put in a self tapper sheet metal screw with a nitrile oring on it.. that will stop the leak.. now jbweld over it..
keep in mind a pin hole leak like that likely menas there are more of them in there from water.. just be prepaired..
soundguy
I have used this Stuff in the Link Below
Lots of times with great success.
You can get it at Wal-mart.
Seal-All works Good
http://www.eclecticproducts.com/sealall.htm
My tank got a leak because a stone got between the tank and a plastic guard.I used the same method to fix the leak.My 77 chevy had the same problem.
I fixed an oil pan with a screw an oring before.. held long enough till I got it fixed correctly..
soundguy
