JD 110 OVERHEAT
Anonymous-0
I have a 1964 JD 110 with the Kolar 8 hp engine. It starts and runs fine, but after about 20-30 minutes of use, severly overheats. The head fins are clean and the fan blows fine over the engine. Does anyone have any idea as to why this happens.
If ur sure airflow in blower shroud is ok u may check ur poing gap for this can mess with timing
causing some problems
A lean fuel condition can also cause overheating
check valve clearance also wouldnt hurt
good luck
Thanks for your input. In my search for info I found this online Kohler manual for the K181. The JD dealer provided me with the wrong point gap. I am going to reset and try again.
http://www.kohlerengines.com/common/resources/tp_2379.pdf
