Thank you for the information. I am going to look at a JD planter that looks to be a 246. Been setting in a barn for the last twenty years or so. Was in working order when placed in the barn. Seed plates and hopper may be in bad shape?(quoted from post at 21:41:08 04/12/20) We had one when new and I don;t think it ever had a model on other than paint. And they did not put serial numbers on implements at that time.
hanks everyone for the information(quoted from post at 06:15:12 04/13/20) The 246 & 247 are the only 2 row 3 point hitch planters JD made and only difference is 246 has only what is called a corn seed box while the 247 has a combination corn-cotton seed box. Those not sold here in Ohio so never saw one of those boxes. As far as plates unless visibly broken they will be OK. Boxes can be either good or rusted out but average person should be able to make new if needed but boxes from 290-490-494 and other newer larger planters fit. What you need to check is wear on box bottom plate and operation of the seed knockers. 2 different bottom plates, both flat onone side, other side one has a narrow grove for larger flat kernel corn, second type a large flat grove foe giving a heavier seed rate for soybeans. Same plate fits all Deere plate planters except horse drawn.
es, might be in a week.(quoted from post at 07:24:17 04/14/20) Will you let us know what you find and if you get it?
hank you very much for your offer.(quoted from post at 02:44:45 04/15/20) I have a 246/247 I fixed up and use to plant Sunflowers. It was well used and neglected when I bought it. Took quite a bit of work and some farm engineering to make it work as it should. Bearings are all steel on steel and if not greased properly will be worn out.
I made brackets and used roller bearings on the drive shaft then used Babbitt to fix the worn out bearings on the chain shafts. Rusted out Seed hoppers were fixed with Bondo and found Sunflower plates on eBay. Fertilizer hoppers and components were toast and not worth trying to save.
Was well worth the effort, at least to me. If you get it and it needs any TLC I'll be happy to give details on what I did to get mine in working order.
osted update on jd corn planter. thanks for your information.(quoted from post at 07:24:17 04/14/20) Will you let us know what you find and if you get it?
