jodonnel
My neighbor has a JD 24T that needs to be fixed (not sure exactly what's wrong with it) but he said that if I get it up and running I'm free to use it whenever I want. It's been on their family's farm its whole life and has been shedded since it was last used, I think the needle might be bent, but I know next to nothing about square balers.
Does anyone know of anyone in Western Pa that works on square balers (preferably someone who knows a JD 24t) and does good work for a fair price? I'm 20 minutes south of Washington PA if that matters at all.
Thanks in advance!
First thing you need to do is get the Op manual for it. JD still sells them for around $30 and there is a lot of trouble shooting tips in it. BTDT on a 14T which is about the same baler just older
Old gave you good information. The operator's manual gives LOTS of information about adjustments, timing, repairs, etc., and explains how the knotters work.
There's no reason a person with basic mechanical skills can't repair a baler.
Call Deere Techpubs @ 1-800-522-7448 for an operator's manual.
(Or watch ebay for a deal on an old original manual.)
BTW, you can look at or print out the PARTS manual for free at jdparts.com
In addition to having a manual, the best way I ever found to trouble-shoot one was to turn it by hand, trip the knotters, continue to turn it and OBSERVE what happens.
I learned hard way there is difference between 24t and 14t balers. old is right to point EARLY 24t and 14t same but later 24t and 14 different, you need serial number to know if early or later model, then JD dealer can tell you which you have. the hard way i learned was to sell a 14t to people for parts for there 24t and had to buy both back from them.....
alot of parts are different from a 14 to a 24 but the basic knotter adjustments will pertain to both, had a knotter on a 200 Case that wanted to miss, turned it over by hand , watched it, readjusted the tucker finger and it worked.
