Anonymous-0
We have a 3010 diesel. After the tractor warms up if we idle down to 1200 rpms or less the oil pressure light will come on. I had our dealer check the pressure with a gauge today. His test shows 14 psi at 1200 rpm and 30 psi at full throttle. He tried to turn up the oil pump screw but it did not change the pressure readings. The service teck was not able to find any specifications on what the oil pressure readings should be. I am thinking about trying strait 30 wt. oil to see if that will help. Any ideas, a weak pump maybe? Or am I looking at an overhaul? We have replaced the sending unit. Thanks
