JD 4020 loader valve A
Bruce E
Sorry guys, can't find my post from yesterday? Putting a westendorf ta25 fel on 1966 PS and plumbing it in. Question is how many GPM joystick should it get. I understand it puts out 18gpm. If i get one lower such as a 10 gpm will it hurt the hydraulic system? Or do i need a 20 gpm or so? Thanks in advance
Bruce, I bought my valve and joystick from the Surplus Center in Lincoln, NE. If memory serves me right there is not a large difference between the differing gpm sizes. I think I installed a 25 gpm valve on my 4020 and it works well. Hope this helps. Mike
Make sure you install a closed center valve and tee off the hydraulic line going to the rock shaft. You will be pleased with how well it works.
The lower flow pump will restrict the flow to the loader. In my case I installed a flow control valve between the 4020 and the loader valve because I've found my loader only needs about 5 gpm to move as fast as I can keep it under control without having the feather the valves too much.
What you need for flow rate depends on how much you want to toss stuff and how fat the cylinders are.
Gerald J.
