I have a John Deere 4320 with a Hinson cab. Is there an aftermarket AC kit out there for this that would be worth the money or am I better off to try and find a used roof mount that was factory installed originally ? This did not have factory AC. Thank you !!
I saw a 4320 once with the Roll-guard/Hinson cab that had Eagle aftermarket air on it. I don't know if you could still buy a set up or not. I used to have a '72 4020 with factory air. There is a lot of stuff that you would have to change to add the factory air. Fan and fan pulley, crank pulley, radiator, evaporator, roof top condensor unit, compressor and brackets, lines, plus all the wiring, switches and relays. I would think you would almost need a donor tractor to make it all work.
Thanks for the reply. I knew it was not going to be a cheap thing to do , and that is why I was kind of thinking maybe a new aftermarket all in one set up. The tractor has been such a good one, I don't want it to fall apart but yet the older I get the nicer the AC would be . I would like to have the 4520 and 4620 for collecting . Any other aftermarket AC ideas would be greatly appreciated.I"ll check on the eagle kit. Thanks
