JD #52 plow
Jud
I am restoring a JD #52 plow and I need to know what size of tire is supposed to be on them. Anyone know?
Stan , I'm not too sure the 52 ever came with rubber! It was an option on the later #4 plows , but I bet this 52 was fitted with rubber after the fact.
I agree with you. We had a No. 51 plow that we got in 1943 and a No. 52 that we got in about 1947...neither had rubber tires.
Stan
I took a look at the manual I mentioned, and it does ideed mention 24" wheels and 4" tires. No mention of anything like tire size other than that. I wonder if they were just a hard rubber cover on the wheel?
Stan
Most had the steel rims cut off and rim for rubber put on in the 50's and a 6:00 X 15" was the likely size but it could also have had a 6:70 X 15" also used as they were as close to the orignal steel wheel as possible. Depending n what junker car was setting around they might have used a 5:50 X 17" as well.
