Live in WV, own a JD 5203 tractor. Starter went bad, so replaced it. Crossed the wires on the starter so when connected the battery heard an audible pop like a fuse blown. (edit: switched the wires on the starter, starter works with a screwdriver) Checked all fuses under the steering column, they are good. Replaced the inline 100 amp fuse, replaced starter solenoid switch. there is 12.5 v at starter.
Lights do not come on, nor does anything happen when turning key switch. Not sure where to go from here, appreciate any suggestions. Thanks.
