JD 520LP clutch
My JD 520LP clutch will not lock in. The tractor will do fine as long as I hold the clutch lever forward or in the back position. Things I should check? Thanks.
Make sure your flywheel is tight with no end play
take the cover off the clutch remove three cotter
pins turn nuts one hole at time until clutch feels right.
