Have a jd 55 plow with the trip wheel with the cast insert. bought from wife's grandpa's estate. restored, but he put a new tire on the old rim and it won't beed to it, i trip it and when it tries to lift spins the tire and sheers the valve stem. where these tires originally solid rubber? stem passes through center of the rim, which then hits the cast iron center when rim is re clamped on...
attached is the style of rim & hub it has. inside o f rim is very irregular where the tire would bead against which keeps it from doing so...
