Got this dozer and it would not move,the guy had messed with the control valve cause he was having reverse problems,i took the valve off and took it to john deere and they fixed it,well the forward gears work fine and the reverse does not,it will go in reverse but won't move until i throttle up,(wide open)but at idle speed it is only caring 30 psi and once it hits a 100 psi it starts to move,the max of pressure i can get out of it is 125 psi and that is the motor wide open,done the filter and the screen and put new fluids back in but still the same,how do i build the pressure up without takeing the pump out or is that the only way,or do you think i have a internal problem,looking for some info.Thanks
