JD 720 or JD G
According to external_link the 720 has 53.41 Drawbar HP and the G has 34.49 Drawbar HP. the 720 has less cubic inches too.
external_link is a good site to find info & I think most of the info they have is correct.
Most Gs have had gas pistons put in them and had the manifolds changed also. That gave the G hp ratings that was never it the nebraska tests
It is not to hard to get 60 hp out of a g just changing it to gas. The 720 is a much nicer tractor to run though. I have a 70D standard that is restored with .045 730 pistons and such and my son has a 48 A with a power block and a pulling cam with a few other tricks that will outpull any of my two cylinders. We use the A for raking hay and my son calls my 620 the turd. I have two G's that I have both blocks bored out .090 -- One has gas pistons and the other has m and w pistons. They were bored out about three years ago and are on the back burner waiting for my broken bones to finish healing
My 2 cents ** G for playing 720 if you are going to use it.
I agree with jdjerry, G to play and 720 or 730 to work plus a 720-730 will do the same job on 1/2 the gas a G will take.
depends on what power you are looking at i got a 51 that will out hoss my 70 gas anyday but when it comes down to farm work the 70 is better holds rpms better i think the a just has a butt load of torque is y it has so much hoss
The G only is better to play with if it has been turned up. stock for stock, the 720 is better for both pulling and farm work...3 pt, power steering, rollomatic!
